Im sending json logs from filebeat to logstash to opensearch to grafana and everything is working perfectly (if it comes to integer data) i can even see that opensearch receives my string fields and boolean fields and even reads them.
but when i want to make a dashboard to visualize some strings and booleans, it only finds my integer fields
Can someone help me visualize Strings on grafana and not only numbers.
Welcome
Please post some sample json?
{“pinghost”: “http://www.google.com”, “timestamp”: “2022/05/08 15:20:27”, “randomm”: 2811, “randombool”: false, “nbr_successes”: 3, “percentage_successes”: 100.0, “testbool”: true, “percentage_successes”: 100.0}
this is a json im using
it reads all the integers but not the strings or booleans
Like this? @kiritoirl
Under value options, choose all fields
Yeah i selected it countless times, but im not getting the strings or booleans
Its because i work with datasource opensearch and it doesnt show me all fields even when i select all fields
You do not have any of those other fields selected in your Lucene query. You just have an aggregatiom query
Yeah im not sure what i can put there, im really bad with queries
can you maybe help?
