OS: Ubuntu 22 , Grafana lattest (12.0) -
Dynamic dashboards -
Using Opennms plugin (lastest) repeat for variable. -
What happened?
While using repeat for variable on stats or any other panels, the panels are repeated but the node has value $__all instead of specific node value in every panel. -
The repeat for variable should pass the specific values of nodes(variable) in each repeatted panel -
No -
It was working on earlier versions of grafana but on versions 11.3.0 and latest, it is not working.
