The following is created generating appropriate JSON and using the grafana API. I want both queries to be visible in the panel time series, but when I create it using the API, only the last (here name2) is displayed. If I remove the datasource2/name2 query and create it manually in the exact same way in the UI (I have compared the 2 JSON objects, they are the exact same), it works just fine, like this:
Thank you for pointing me in the right direction. The issue was that both queries had the same refId, which was “A”. Making these unique fixed the problem.
