However, I am trying to use: $_timeFilter for my Time Series of data - but I only need the date portion (as I am not getting all my data set back - due to the time element starting at the current time).
So;
$__timeFilter(created)
Gives me as a generated SQL:
created BETWEEN ‘2020-03-24T15:33:18Z’ AND ‘2020-03-31T14:33:18Z’
However, I need to use it with the $_timeFilter so the Time Series in the output works…
If I just use convert - then my Time Series doesnt seem to work…
You will need to use the $__timeFrom() and $__timeTo() macros instead of $__timefilter and build your own BETWEEN clause.
$__timeFilter() will generate something like BETWEEN ‘2017-04-21T05:01:17Z’ AND ‘2017-04-21T05:06:17Z’ which is not a datetime that you can pass into the convert function.
Hi, I tried both methods and the result is the same.
With timeFilter or timeFrom/timeTo the query inspector returns the same date and time ‘2024-12-17T03:00:00Z’ and ‘2024-12-18T02:59:59Z’ when I select 2024-12-17 00:00 to 2024-12-17 23:59 actually.
I am in UTC-03 as well as the dates and the server, what I find strange is that when everything is configured in that time zone it applies the variations in the dates as if the server was by default in UTC+00.
In my case I solved it by applying the UTC+00 time zone to the date ranges in the time filter and another important fact is that when I was working on a view in mssql the date column was formatted as varchar(16) which also generated a conflict.
The solution to my case:
_ UTC+00 in time filter
_ Datetime format in database column
Thanks to everyone for commenting, have a great end of the year.
