Is it possible to define diferent colors for y-axis values ?
Maybe some special code in panel json ? Or next improvement ?
Thanks.
I don’t believe the y axis font color is configurable. I like the idea, and I think this could make a cool feature request. The best way to get a feature request included is to start a discussion in the repo:
It’s only a little improvement, but you can see on the first sight which curve is with same color.
+1 to this request. I’m using Boom Panel and the thing is that Axis colors are pregenerated based on light\dark theme of Grafana, so, when I try to use Boom Theme “Dark Grafana” when I have Light theme enabled I see following picture
