During the whole month, the bars in my graph are correctly aligned right over the right date - except on the 1st of each month. On this date, the bar is too wide.
Example:
Grafana 9.0.3-3 on RHEL 9.2 -
On the 1st of each month, the bar should also have its normal wide and be aligned above the correct date. -
I use the query options as shown in the screenshot.
Thanks for advices how to fix this.
