RedHat 8.6
grafana-9.2.1-1.x86_64
zabbix-agent2-6.0.9-release1.el8.x86_64
zabbix-get-6.0.9-release1.el8.x86_64
zabbix-sender-6.0.9-release1.el8.x86_64
zabbix-server-pgsql-6.0.6-1.el8.x86_64
zabbix-sql-scripts-6.0.6-1.el8.noarch
zabbix-web-6.0.6-1.el8.noarch
zabbix-web-deps-6.0.6-1.el8.noarch
zabbix-web-pgsql-6.0.6-1.el8.noarch -
I’m trying to make a dashboard variable using a regex capture illustrated here: regex101: build, test, and debug regex
The string examples are copied from the results in the Zabbix API, and you can see that the regex appears to be valid. -
What happened?
You can see the result in the screen shot, that last match is literally a blank string. This should actually be the “X0” match illustrated in the regex101 example, but for some reason Grafana is returning this as a blank string instead. This causes a blank entry in the returned values for the variable, and a bunch of other weird side effects on panels, etc. because of that blank string. -
I would it expect to return a proper Regex capture as illustrated on the regex101 example. You can see on that test, both lines match and return a valid string. -
See previous comments. -
No errors, it just returns the blank string as if it’s a valid value. -
N/A
I should note, it’s possible this is a Grafana core problem and not the Zabbix plugin. However, I figured I would start here since we are using the Zabbix API plugin.
