OAuth/OIDC - Generic-Auth User Mapping
  • I am using Grafana v12.0.2 (5bda17e7c1)
  • Authentication: Generic OAUTH
  • User mapping
    • Role Attribute path = contains(“memberOf”[], ‘CN=App - RestcloudPRP Grafana Admin,OU=site,DC=office,DC=zone,DC=brk,DC=org’) && ‘Admin’ || contains(“memberOf”[], ‘CN=App - RestcloudPRP Grafana Editor,OU=site,DC=office,DC=zone,DC=brk,DC=org’) && ‘Editor’
    • Organization attribute path = memberOf
    • Allow assign Granfana admin = Enabled
  • Provider PINGID (OIDC)
  • Issue: I’m using the role attribute path, and I’m still getting group access as a viewer, not the assigned Admin Role.
I’m sorry to hear that you’re experiencing difficulties.
Grafana can provide valuable information about certain issues through its own debug logs. These logs can help troubleshoot and identify the root cause of problems (especially if they are related to anything that can be configured via Grafana config file).
To enable debug logging edit the configuration file grafana.ini:
[log]
# Either "console", "file", "syslog". Default is console and file
# Use space to separate multiple modes, e.g. "console file"
mode = console file
# Either "debug", "info", "warn", "error", "critical", default is "info"
level = debug
Then restart grafana for the setting to go into effect.
Replicate the problem and check Grafana logs. However, before posting the debug logs on the community forum, it is important to sanitize any private details such as passwords, tokens, IPs, names, … By including properly formatted debug logs (with sanitized information) and details about your installations (e.g. exact Grafana version, how it was installed, OS details, …), you greatly enhance the chances of receiving accurate assistance and solutions.
