As documented at Cloud tests from the CLI there is an optional “note” field within the "loadimpact" key, which I assume should show up on my tests summary page under "note". However, it doesn’t seem to have any effect. The only way I can make a note appear is if I manually click on “Create note” and type one in in the UI.
Any idea how I can automatically create a note within the script? I’m running locally with k6 run -o cloud and using the following:
export let options = {
ext: {
loadimpact: {
projectID: 123456,
note: "bar",
The name: "foo", part works fine, note: "bar" appears to have no effect.
