Noob question on calculation
I’m trying to create a Dashboard that shows various KPI’s from my Magento shop. I’ve managed to create “calculated fields” in other dashboard solutions in order to calculate my GP1 but have failed utterly in Grafana. Any help on how to do this would be highly appreciated.
Cheers
Zoran
Have you tried to apply Transformations on your data?
The Add field from calculation transformation should solve your issue.
If you have some trouble using it, please give a bit more detail on your use case and your data format.
Thank You so much!
That solved my problem.
