hi,
We are evaluating Grafana for developing dashboards for vehicle metrics where a natural x-axis is the vehicle mileage that will be available in the data set. Will Grafana be able to support this use case?
Thanks.
hi,
Thanks.
I don’t think this is supported natively in Grafana, unless you’re looking for a histogram plot. This plugin might be what you’re after: https://grafana.com/plugins/natel-plotly-panel
