10.3.3 and amazon linux 2 -
configure the dashboard using prometheus and node exporter -
create a standalone server -
What happened?
nodes already remove from prometheus config file but still showing in grafana dashboard. -
Firstly, after removing the nodes from the config file are you restarting the Prometheus service/s?
But even when you do this, if there is old data from the nodes still in Prometheus then Grafana will continue to show the data. Depending on how many days of data you have configured Prometheus to keep then the data will disappear from Grafana after that number of days.
I don’t actually know how to manually remove specific node data from Prometheus, in my case I just flush the entire Prometheus data as it’s just for my use and I can clear history from time to time without a problem. If you can do the same then my hacky way to clear ALL Prometheus metrics is this:
rm -rf /var/lib/prometheus/metrics2/*
