Hi, I am building an application based around docker multi containers. I would like to have my node applications login also login the user to their grafana dashboard. I have attempted implementing auth proxy but failed. I can see my grafana.ini settings working as they get passed from the docker compose file. The ini is below.
Summary
[users]
allow_sign_up = false
auto_assign_org = true
auto_assign_org_role = Editor
[auth.basic]
enabled = false
[auth]
disable_login_form = true
[auth.proxy]
enabled = true
header_name = X-WEBAUTH-USER
header_property = username
auto_sign_up = true
[server]
protocol = http
http_addr =
http_port = 3000
domain = localhost
enforce_domain = false
root_url = %(protocol)s://%(domain)s:%(http_port)s/
serve_from_sub_path = true
I am trying to use express-http-proxy or http-proxy to complete this but I don’t seem to be doing it correctly. I am not sure how to get the users set up, they can even just all log into the same viewer user. Im just not sure what I else to do as there are very few examples on how to achieve this. The example in the documentation use an Apache server is that necessary in my case?
My node app is running on 8080 and the code I recently have tried it below. Does anyone have any suggestions?
Summary
var proxy = require(‘express-http-proxy’);
var app = express();
app.use(’/grafana’, proxy(‘community.grafana.com’, {
proxyReqOptDecorator: function(proxyReqOpts, req) {
// you can update headers
const bodyData = JSON.stringify(req.body);
proxyReqOpts.headers['Content-Type'] = 'application/json';
proxyReqOpts.headers['Content-Length'] = Buffer.byteLength(bodyData);
proxyReqOpts.headers['X-WEBAUTH-USER'] = 'test';
// you can change the method
return proxyReqOpts;
proxyErrorHandler: function(err, res, next) {
switch (err && err.code) {
case 'ECONNRESET': { return res.status(405).send('504 became 405'); }
case 'ECONNREFUSED': { return res.status(200).send('gotcher back'); }
default: { next(err); }
