The OS of the server is Linux and Grafana is V7.5.7. -
I’m trying to draw a graph with about 3000 nodes. -
I generated a json with nodes and edges according to the structure detailed by nodegraph. I was successful with minor graphs of about 100 nodes. -
What happened?
In my local Grafana, I was successful in show that big graph, however in the Grafana in my server it breaks and don’t show the graph. There is no error message in the dashboard. I have set all the timeouts limits I had in my API and server configuration files envolved with the process. -
I expect to see the entire graph drawn on the screen. -
504 Gateway Time-out
nginx/1.10.2 -
No online instructions was followed.
Welcome,
In your local grafana where it worked, were you pointing to the same api on your server (where things do not work)?
What version if your local grafana?
Does this work in latest version of grafana? You are on a very old version of grafana
Realistically, how use-able is a 3000 nodes in your workflow?
My problem was solved, I found what was wrong. As to the graph size, I’m trying to control the number of levels that are drawn at once. Is there any feature in the plugin so that I can draw the graph let’s say from 4 to 4 four levels until it’s complete?
What does this 4 to 4 mean?
