Version 8.0.4 (commit: 81fef5b4b4, branch: HEAD) -
What happened?
t=2021-07-05T20:48:05+0200 lvl=eror msg=“Render request failed” logger=plugins.backend pluginId=grafana-image-renderer error=“TimeoutError: waiting for function failed: timeout 60000ms exceeded” url=“http://grafana.staged-by-discourse.com/dashboard-solo/db/icinga2-influxdb-host?var-hostname=host1&var-service=service11&var-command=check_service11&panelId=1&orgId=1&width=900&height=280&theme=dark&from=now-6h&to=now&trickrefresh=now&render=1” -
default config with folowing changes:
sed -i “s/;http_port = 3000/http_port = 3000/g” “/etc/grafana/grafana.ini”
sed -i “s/;enabled = false/enabled = true/g” “/etc/grafana/grafana.ini”
sed -i “s/;allow_embedding = false/allow_embedding = true/g” “/etc/grafana/grafana.ini”
grafana-cli plugins install grafana-image-renderer
Graphana Service is started up…
I made only an Upgrade.
- The Graphs are displayed if I navigate to the page manually. When I am trying to open the link above I get “timeout error - you can set timeout in seconds with &timeout url parameter”.
