Nodegraph context menu issue
Has anyone else noticed an issue with the node graph context menu? When clicking on a node, the context menu appears, but not at the expected position. It works fine when the node graph is at the top of the dashboard. However, if the node graph is placed further down the dashboard (e.g., 5th or 6th panel) and requires scrolling to view, the context menu doesn’t appear near the node. Upon closer inspection, the menu is actually rendering far below the visible area, only visible when zooming out completely. The context menu perfectly populates if we click View and go into the visual. Out in the dashboard, the above is the problem.
Does anyone know how to get the context menu to populate properly, regardless of the node graph’s position in the dashboard? Whether it’s at the top or buried below other visuals, the context menu should ideally appear adjacent to the node, not somewhere else on the page. Any insights or similar experiences would be appreciated!
