Is there no timezone global variable (Grafana 8.x) ? (it seems very surprising)
If not, any chance it is on the roadmap?
Thanks so much
Best
Benoit
Thanks so much
Best
Benoit
For what purpose and how would you expect to use such a variable?
Almost everything Grafana does expects data to be in UTC, and local timezones
cause all sorts of problems when there are two instances of 2:38am in one day,
for example.
Where / how do you think you need to use a local timezone indicator?
Antony.
Thanks, I should have specified that.
I work mostly with the PostgreSQL data source & raw SQL queries but I think it could apply to other data sources as well.
I have two use cases I would need that:
Creating some text columns in the query to render/prepare text on the server-side involving timestamps → I need the browser timezone to know how to format my timestamps (which are in UTC in the database, as it should be)
I have queries in which I only care about the date component in the time selector (i.e. i don t care about selected time hh:mm) and just want to filter based on date. But if i filter on timecolumn::date (or date_trunc(‘day’, timecolumn) ) i have inconsistencies with the time selector because of time zones.
For now, I can set the PGTZ environment variable when running the grafana client (docker) to render the datetimes in some timezone (and also use select current_setting('TIMEZONE')) but this is not the browser timezone.
Does it make sense?
Thanks so much!
Best
Benoit
Another example: I love to use the plotly plugin (Plotly panel plugin for Grafana | Grafana Labs) to have total freedom on rendering via javascript & plotly.js, beyond stock Grafana visualization.
If I want to generate some “placeholders” for values in my query (that will then be ultimately joined and values returned for the plotly visualization), then:
select * from generate_series(date_trunc('day', $__timeFrom()::timestamp),
date_trunc('day', $__timeTo()::timestamp ),
'1 day')
returns (for example):
2022-05-06 20:00:00
2022-05-07 20:00:00
2022-05-08 20:00:00
2022-05-09 20:00:00
Instead, with
select * from generate_series(date_trunc('day', $__timeFrom()::timestamp at time zone 'EDT'),
date_trunc('day', $__timeTo()::timestamp at time zone 'EDT'),
'1 day')
The answer in Grafana is correctly:
2022-05-07 00:00:00
2022-05-08 00:00:00
2022-05-09 00:00:00
2022-05-10 00:00:00
(but i need to replace EDT with the browser timezone)
Note that this use of “placeholders” is also very useful if I want to display data in a conventional Grafana table while being sure to include metrics for all days (e.g., with a full outer join), even if there was no data whatsoever for that day in the database (i.e. not caught by a group by)
What do you think?
Any query trying to create placeholders timebuckets between __from and __to (e.g., for a simple Table visualization) could not do that correctly without having access to the timezone, no?
Thanks!
Best
Benoit
I have the same need for a global variable timezone.
Here is a Github Discussion (former Feature Request):
Consider upvoting and commenting your use case there.
