What Grafana version and what operating system are you using? 8.3.3 Linux
To see data in Dashboard -
What happened?
sum(node_namespace_pod_container:container_cpu_usage_seconds_total:sum_irate{cluster=“$cluster”, namespace=“$namespace”}) / sum(kube_pod_container_resource_requests{job=“kube-state-metrics”, cluster=“$cluster”, namespace=“$namespace”, resource=“cpu”})
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No Data is returned
- Did you follow any online instructions? If so, what is the URL? Yes
