I am trying to configure auto login using nginx as auth proxy, I am successfully able to authenticate but my problem comes when grafana loads all static files are 401.
my nginx configuration
#i also tried /grafana by enabling it in the grafana.ini
location / {
secure_link $arg_md5,$arg_expires;
secure_link_md5 "$secure_link_expires$uri enigma";
if ($secure_link = "") { return 403; }
if ($secure_link = "0") { return 410; }
proxy_pass http://grafana.staged-by-discourse.com;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Session-Token $http_x_session_token;
proxy_set_header X-WEBAUTH-USER $arg_user;
proxy_set_header Authorization "";
#rewrite ^/auth(.*)$ /$1;
as you can see all of resources are 401 below is link that i use for authentication
http://localhost/?md5=JSyq8fW04y5L7Khd0BoZ9g&expires=1686614400&user=admin
