Newrelic statsd integration in circle ci
I am struggling to send k6 data to new relic via new relic statsd integration when running from circle ci. Same code works fine when run in local.
IS THERE A COMMAND I AM MISSING TO MAKE NEWRELIC STATSD LISTEN TO K6???
here is the circle ci config.yml code
docker pull loadimpact/k6:latest
docker run \
  -d --restart unless-stopped \
  --name newrelic-statsd \
  -h bridge \
  -e NR_ACCOUNT_ID=******** \
  -e NR_API_KEY="****************" \
  -p 8125:8125/udp \
  newrelic/nri-statsd:latest
docker run -i -v $HOME/*********/lib/shim:/ci/ loadimpact/k6:latest run --out statsd /ci/script.js
latest: Pulling from loadimpact/k6
b1bc80d0: Pulling fs layer
b9c5a8d0: Pulling fs layer
Digest: sha256:2718b83ca8d60197b883d9c81d3d54b0e9c4ac9f9f366573048b7e2cadbc0b7e
Status: Downloaded newer image for loadimpact/k6:latest
docker.io/loadimpact/k6:latest
Unable to find image 'newrelic/nri-statsd:latest' locally
latest: Pulling from newrelic/nri-statsd
9388f04a: Pulling fs layer
025ca458: Pulling fs layer
3749d02f: Pulling fs layer
6418287b: Pulling fs layer
Digest: sha256:b0e3272d94d83f2f0a5898d686cbe4a2047a59269fafd44bcc021e559b4c6cc9
Status: Downloaded newer image for newrelic/nri-statsd:latest
637e973cf2ea50fc52bb896f247495004ab9fed3832413beb91a67b54fb7b509
  / __________ \  |__| \__\ \_____/ .io
  execution: local
     script: /ci/script.js
     output: statsd (localhost:8125)
  scenarios: (100.00%) 1 scenario, 1 max VUs, 10m30s max duration (incl. graceful stop):
           * default: 1 iterations for each of 1 VUs (maxDuration: 10m0s, gracefulStop: 30s)
running (00m00.4s), 0/1 VUs, 1 complete and 0 interrupted iterations
default ✓ [ 100% ] 1 VUs  00m00.4s/10m0s  1/1 iters, 1 per VU
     data_received..............: 3.8 kB  8.7 kB/s
     data_sent..................: 1.7 kB  4.0 kB/s
     http_req_blocked...........: avg=47.33ms  min=47.33ms  med=47.33ms  max=47.33ms  p(90)=47.33ms  p(95)=47.33ms
     http_req_connecting........: avg=1.41ms   min=1.41ms   med=1.41ms   max=1.41ms   p(90)=1.41ms   p(95)=1.41ms
     http_req_duration..........: avg=332.89ms min=332.89ms med=332.89ms max=332.89ms p(90)=332.89ms p(95)=332.89ms
     http_req_failed............: 100.00% ✓ 1        ✗ 0
     http_req_receiving.........: avg=93.79µs  min=93.79µs  med=93.79µs  max=93.79µs  p(90)=93.79µs  p(95)=93.79µs
     http_req_sending...........: avg=197.77µs min=197.77µs med=197.77µs max=197.77µs p(90)=197.77µs p(95)=197.77µs
     http_req_tls_handshaking...: avg=37.52ms  min=37.52ms  med=37.52ms  max=37.52ms  p(90)=37.52ms  p(95)=37.52ms
     http_req_waiting...........: avg=332.6ms  min=332.6ms  med=332.6ms  max=332.6ms  p(90)=332.6ms  p(95)=332.6ms
     http_reqs..................: 1       2.315569/s
     iteration_duration.........: avg=380.63ms min=380.63ms med=380.63ms max=380.63ms p(90)=380.63ms p(95)=380.63ms
     iterations.................: 1       2.315569/s
Hi @pradeep
Welcome to the community forums! :wave:
Am I getting you right that if you run the commands from above (locally run docker containers) it works, but only when you’re running in CircleCI it fails? :thinking:
Cheers
The above log is from circle ci. Test is running succesfully, but data is not flowing to NewRelic, though i can see output is routed to statsd integration.
The same setup works fine when i am executing in my mac machine. So want to understand , where am i going wrong when executing the same script in circle ci. Does it have to do anything with connection between two images loadimpact/k6 , newrelic/nri-statsd
Hey @pradeep
To be honest, I’m not familiar with CircleCI. However, one thing that potentially, I guess can be an issue is that you start newrelic/nri-statsd:latest in a detached mode, and straight after loadimpact/k6 maybe the time in between isn’t enough for starting the newrelic/nri-statsd:latest :thinking:
Let me know if that helps,
Cheers
Any updates? I am stuck at same point
