Hi All,
In grafana I need to configure BMC remedy REST API, using GET method need to fetch results in JSON format and create dashboard in GRAFANA. Need your advise or help to create the dashboard.
I have installed grafana and JSON service plugin in the my local PC. Please let me know If you need any information from my end.
Regards,
Surya Anjan
Re
