I have timestamp data
3 datasets in an app
https://batch3.asicseer.com/graphs/?rig=2ac23b&panel=batch3&type=watts&json=yes
Is this possible in grafana?
Can you describe what you are trying to achieve as dashboard ?
Good Luck
sure, you can visualize this in Grafana! just go ahead and habe fun
