NAS Synology permission denied for docker compose grafana, prometheus and loki
issue which is happening only on NAS Synology for grafana, loki, prometheus containers:
ERROR: for prometheus  Cannot start service prometheus: OCI runtime create failed: container_linux.go:367: starting container process caused: chdir to cwd ("/prometheus") set in config.json failed: permission denied: unknown
this doesn’t help:
  init-prometheus:
    profiles:
      - init
    image: ubuntu
    user: root
    command: chown -R 65534:65534 /prometheus
    volumes:
      - ./prometheus/data:/prometheus
I run prometheus and other containers “normally” without any strange things for access:
  prometheus:
    image: prom/prometheus
    restart: unless-stopped
    environment:
      - TC=UTC
    volumes:
      - ./prometheus/prometheus.yaml:/etc/prometheus/prometheus.yml:ro
    command:
      - --config.file=/etc/prometheus/prometheus.yml
      - --storage.tsdb.path=/prometheus
      - --web.enable-remote-write-receiver
      - --log.level=debug
    ports:
      - 9090:9090
How to fix this and at the same time doesn’t affect security of NAS Synology? What is the best practice for this use case?
  1. add new user in Synology panel called “grafana”.
  2. cat /etc/passwd | grep -i grafana to get user-id:group-id
  3. dokcer-compose.yaml
    init container
  init-prometheus:
    profiles:
      - init
    image: ubuntu
    user: root
    # command: chown -R 65534:65534 /prometheus
    command: chown -R user-id:group-id /prometheus
    volumes:
run prometheus
  prometheus:
    user: user-id:group-id
the same work for grafana, prometheus, loki.
change user-id:group-id with your ids.
