Permission denied when adding new Prometheus datasource
  • What Grafana version and what operating system are you using? 9.2
  • What are you trying to achieve? add Prometheus as datasource
  • How are you trying to achieve it? add prometheus from Grafana datasources settings - this is a new vanila install
  • What happened? getting “permission denied” error
  • What did you expect to happen? add prometheus server
  • Error reading Prometheus: Post “http://:9090/prometheus/api/v1/query”: dial tcp :9090: connect: permission denied
    Grafana and Prometheus installed on the same hosts monitoring 3-node Cassandra cluster
