(9.0.2) -
Display time based data on a time series graph and create a total based on the grafana time scale selected. -
Using the below mySQL table and SQL -
What happened?
The graph seems to be shown correctly but any totals are for the whole data set.
Not the selected i.e. last 7 days etc. -
I have other times series not using a unix time stamp. I was expecting the total to only show for the time scale selected at the top of grafana i.e. 7 days, 2 days etc⦠-
CREATE TABLE usage (
interval_start int(10) UNSIGNED NOT NULL,
interval_end int(10) UNSIGNED NOT NULL,
consumption decimal(12,4) NOT NULL,
meter char(128) NOT NULL,
tariff char(128) NOT NULL,
fuel enum(βelectricityβ,βgasβ) NOT NULL,
rate_exc_vat decimal(8,4) DEFAULT NULL,
rate_inc_vat decimal(8,4) DEFAULT NULL,
price_exc_vat decimal(8,4) DEFAULT NULL,
price_inc_vat decimal(8,4) DEFAULT NULL,
reduced_rate_exc_vat decimal(8,4) DEFAULT NULL,
reduced_rate_inc_vat decimal(8,4) DEFAULT NULL,
reduced_price_exc_vat decimal(8,4) DEFAULT NULL,
reduced_price_inc_vat decimal(8,4) DEFAULT NULL
) ENGINE=InnoDB DEFAULT CHARSET=utf8;
INSERT INTO usage (interval_start, interval_end, consumption, meter, tariff, fuel, rate_exc_vat, rate_inc_vat, price_exc_vat, price_inc_vat, reduced_rate_exc_vat, reduced_rate_inc_vat, reduced_price_exc_vat, reduced_price_inc_vat) VALUES
(1660573800, 1660575600, β0.0660β, βE6S13β, βG-1R-AVRO-VAR-21-09-26-Aβ, βgasβ, β2.7738β, β2.9125β, β0.1831β, β0.1922β, β2.7738β, β2.9125β, β0.1831β, β0.1922β),
(1660575600, 1660577400, β0.0490β, βE6S13β, βG-1R-AVRO-VAR-21-09-26-Aβ, βgasβ, β2.7738β, β2.9125β, β0.1359β, β0.1427β, β2.7738β, β2.9125β, β0.1359β, β0.1427β),
(1660577400, 1660579200, β0.0540β, βE6S13β, βG-1R-AVRO-VAR-21-09-26-Aβ, βgasβ, β2.7738β, β2.9125β, β0.1498β, β0.1573β, β2.7738β, β2.9125β, β0.1498β, β0.1573β),
using sql of
SELECT consumption, FROM_UNIXTIME(interval_end) AS datetime FROM usage WHERE fuel = βgasβ
and a transform of
Reduce > reduce fields >calculations > Total
But this gives me a complete table total that does not change with grafana date filtering as my other non unix date panels do.
Any help would be greatly appreciated, Completely out of my depth.
using the query builder I did get
db query error: Error 1064: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near βusage WHERE interval_end >= 1640882140 AND interval_end <= 1672418140 GROUP BYβ at line 4 -
no
