MySQL Data Source Unreseponsive
I’m trying access my MySQL plugin for Grafana, but found it wasn’t connecting. Upon going to the data sources page to diagnose the issue I found the plugin was unresponsive.
After a while the loading just timed out. It gave me an option to delete the data source, but that also resulted in an error
This seems like an outage or issue with the plugin but I’m not sure because I can’t add another MySQL data source.
Device Info:
Grafana: v8.0.6 (68fe9e3431)
OS: Ubuntu 20.04.2 LTS
Are you running Grafana from a docker image? If not, to troubleshoot, can you run this command and see if Grafana works properly?
docker run -p 3000:3000 -e "GF_FEATURE_TOGGLES_ENABLE=ngalert" grafana/grafana:8.1.0-beta3
