I’ve got two time based series, and I want a graph of them multiplied together. Spent a fair bit of time searching, but no luck. Data is stored in influxdb, coming from an openhab install.
I can get the two series shown separately easily enough
SELECT “value” FROM “Solis_AC1Volt” WHERE $timeFilter
SELECT “value” FROM “Solis_AC1Amp” WHERE $timeFilter
but I want to display a graph of the power generated (Volts * Amps)
When using influxdb and grafana you cannot combine two queries. However, looking at influx documentation I can see that they have support for multiplication.
However, from the information I’ve found influxdb doesn’t support joining two measurements (like in your case) and applying mathematical functions. If you had the values from Solis_AC1Volt and Solis_AC1Amp in the same measurement/table the multiply function should work. Another option would be to write a measurement of power generated.
Incase some one else finds this post , this worked for me
SELECT (mean(“v”) * mean(“a”)) AS “VA” FROM
(SELECT mean(“V”) AS “v” FROM “all-energy-monitors” WHERE (“device” = ‘energy-79593ph2’) AND $timeFilter),
(SELECT mean(“A”) AS “a” FROM “all-energy-monitors” WHERE (“device” = ‘energy-79593ph2’) AND $timeFilter)
GROUP BY time($__interval) fill(linear)
