how can I multiply two or more values from an INFLUXDB?
Is this possible with the GUI?
Can one describe this to me?
Thank you.
greeting
Hermann
Thank you.
greeting
Hermann
Thanks. But if the values are from different Hosts?
Is this possible too?
Thx.
Regards
Hermann
What do you mean by different hosts?
I have 6 Hosts. With Telegraf i Send the perfcounter to the influxdb. The perfcounter ist a value for loggedin Users.
I wish to add a Graph where all values are added together.
Added or multiplied? Do you mean that you have one table with a perfcounter field and each host is a tag?
If you just want to sum (add) all the values then this is a standard InfluxDB query using the sum aggregation (this query is grouped by hostname, remove the tag(hostname) and alias by if you want a total without grouping):
Hi.
Great. Thanks It works.
Regards
Hermann
