Multiple X-Y graph grouped by time
Hi friends
Lets suppose i have the following data columns
Time X1 Y1 X2 Y2
2023-08-01 0 1.1 0.5 1.4
2023-08-02 0 1.9 0.5 3
I need to do a X-Y graph with 2 lines (one for each time).
Each line connects points (X1,Y1) to (X2,Y2)
Is this even possible in grafana? If so how?
My data comes from InfluxDb, and I don’t know in front how many X-Y points each line will have (in the above example there are only two and in picture 3) and how lines will i have (depends on the number of time series - 3 in the picture below)
Best regards
Ricardo
Hi @ricardosgeral,
Welcome to the :grafana: community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community :slight_smile:
I think it should be possible (never done myself though) as there is a blog post for this topic:
Also, you can use the grafana core XY Chart panel or use this community one as to test it it out.
I hope this helps.
