I have an InfluxDB series with two dependent tags: org_id and org_name. I have a query that groups by both of these:
SELECT sum(host_count) FROM hosts WHERE $timeFilter GROUP BY time($__interval), “org_name”, “org_id”
I am using a Time Series Aggregations table. I can’t switch to Table format because I need to aggregate over multiple data points.
Is it possible to separate the org_name and org_id tags into separate columns in the Grafana table? This would look like:
org_name, org_id, sum
Foo, 123, 555
Bar, 345, 777
Today I can use an alias like: $tag_org_name, $tag_org_id to put stuff in the same column, but I’d like to split to multiple columns by each group by tag.
