Hello Folks,
im trying to sum some zabbix queries that return a number.
i dont seem to get it… also the help(?) does not have useful examples. With the Functions i use i only get N/A
Hello Folks,
Did you check the panel error in the top left corner?
Singlestat only works with a single query that returns a single series. You need to write one query that does the calculations you want. Not sure Zabbix can combine two queries.
