MS-SQL: Visualize multiple series in Time Series Graph panel with multi-value variable in query statement?
    v.9.3.2
    I want to visualize multiple series in a Time Series graph panel with multi-value variable in my query statment.
    For example on play.grafana.com:
    You can see for every web-server a series.
    I tried different solutions, but it not work with multi-value variable (The multi-value variable is to set the different series)
    My first solution:
    Write multiple query statements for every webserver (no multi-value variable)
    Then it works, but without multi-value variable. It’s static…
When i create the one query with use of multi-value variable, i get only one series because i retrieve only one dataset.
    I want a vizualitation like this one Edit panel - Grafana
    Check picture.
    No.
    I didn’t find any solution…
Thank you so much! It work’s! Didn’t know that transformation opportunity ! :slight_smile:
