Would it be possible to list in MS SQL Query Builder (in Tables drop-down menu) also database views? We have a lot of views in our database with human readable names and we see only encoded table names which are not understandable for us.
Thank you
Thank you
Welcome
Could you please post an imahe of what you mean?
By view I mean
CREATE VIEW machine AS
SELECT
[M3255322] as [timestamp],
[SM432334] as [pressure_01],
[M3f332284] as [temperature_01]
FROM raw_data_table
and this view is not listed in this Table drop-down menu:
is this some sort of a plugin? or something out of the box in grafana cloud?
Hi @stepanurban,
Can you please open an issue in the grafana repository? This way we could track it properly and see if others are also looking forward to this.
