Do we have any way to monitor billing for any specific services like i want the cost details about any specific EC2 instance or any particular container cost usage with grafana.
Thank you
Thank you
You can monitor anything with Grafana which you can get the data for into a
supported back-end data store.
How you get the data into that data store is outside the realm of Grafana; it
is just a tool to help you visualise it.
Antony.
