How to get metrices from eks and ec2 in single grafana dashboard
how to get metrices from eks and ec2 in single grafana dashboard
Hi @naveenkumarstisys,
Welcome to the :grafana: community support forums !!
You can check out the pre-configure Dashboards for Grafana which only need to be imported if you have already configured the AWS Datasource correctly.
Here is the link for EC2 and for EKS
Let us know if this helps.
