v6.6.1 -
monitor Grafana itself with Prometheus -
I have created a ServiceMonitor for Grafana Service, add the network policies to allow the metrics with port service - 443 -
What happened?
Grafana is not emitting any metrics on 443. -
Do I have to any port in the Deployment for metrics…? -
Is it possible to monitor Grafana itself with Prometheus, If yes, what is the metrics port for Grafana. Do I have to open port in Deployment?
grafana can expose metrics about itself for prometheus to scrape.
here are the official docs about it. You’ll need to adjust your settings in grafana.ini / custom.ini and then add a job / target to your prometheus.yml
