Prometheus 2.0 Stats no data
    Grafana v10.1.4 (a676a96d91
    I would like to see the stats of the Promethues 2.0 Stats Dashboard
    I have Grafana and Prometheus installed as well as some jobs set up, server stats and other node exporters like mastodon or synapse are working.
    No error messages or similar
    I can’t find the metric names given in the dashboard even using the explore function
    Install Grafana on Debian or Ubuntu | Grafana documentation
Hey, that means mostly probably you dont have the prometheus_.* metrics in your prometheus server.
Do a recheck on the scrape configs in your prometheus server if it there’s a job to scrape itself or not.
I don’t understand, how can that be done?
You need add a new scrape job :
scrape_configs:
  # The job name is added as a label `job=<job_name>` to any timeseries scraped from this config.
  - job_name: "prometheus"
    static_configs:
      - targets: ["localhost:9090"]
And its explained better here : Getting Started with Prometheus | Prometheus
so i have to create a separate scrape job for prometheus itself too
thought prometheus would do that automatically
//edit
thanks have just entered it, now I see the statistics
