Introduction
Monitoring logged-in Windows users is a common requirement for IT administrators and operations teams. Knowing who is currently logged in, when they logged in, and whether their session is active can help with system auditing, compliance, and operational monitoring.
In this article, we will build a real-time Windows User Monitoring Dashboard in Grafana using:
- Windows Exporter
- Prometheus
- PowerShell
- Grafana
The final dashboard will display:
- Logged-in user names
- Login time
- User state (Active/Disconnected)
- Active user count
Step 1: Verify Windows Exporter Installation
Verify that Windows Exporter is running:
sc query windows_exporter
Expected:
STATE : 4 RUNNING
Step 2: Verify Textfile Collector Configuration
Run:
sc qc windows_exporterExample Output:
BINARY_PATH_NAME :
"C:\Program Files\windows_exporter\windows_exporter.exe"
--log.file eventlog
--collector.textfile.directory="C:\Program Files\windows_exporter\textfile_inputs"
The presence of:
–collector.textfile.directory
confirms that the Textfile Collector is enabled.
Step 3: Create Textfile Collector Directory
C:\Program Files\windows_exporter\textfile_inputsThis directory will contain custom Prometheus metrics.
Step 4: Create PowerShell Script
C:\Program Files\windows_exporter\users.ps1
Paste the following script:
$output = query user
$lines = $output | Select-Object -Skip 1
$metrics = @()
foreach ($line in $lines) {
$line = $line -replace "^\s*>", ""
$clean = ($line -replace "\s{2,}", "|").Trim()
$parts = $clean -split "\|"
if ($parts.Count -ge 5) {
if ($parts.Count -eq 6) {
$username = $parts[0].Trim()
$sessionname = $parts[1].Trim()
$id = $parts[2].Trim()
$state = $parts[3].Trim()
$idle = $parts[4].Trim()
$logon = $parts[5].Trim()
else {
$sessionname = "none"
$id = $parts[1].Trim()
$state = $parts[2].Trim()
$idle = $parts[3].Trim()
$logon = $parts[4].Trim()
$username = $username -replace "\s+", " "
if ($state -match "Active| Disc") {
$value = 1
else {
$value = 0
$metrics += "windows_user_info{username=""$username"",session=""$sessionname"",id=""$id"",state=""$state"",idle_time=""$idle"",logon_time=""$logon""} $value"
$metrics | Out-File "C:\Program Files\windows_exporter\textfile_inputs\users.prom" -Encoding ascii
Step 5: Execute the Script
Run:
powershell.exe -ExecutionPolicy Bypass -File “C:\Program Files\windows_exporter\textfile_inputs\users.ps1”
Step 6: Verify Generated Metric File
Open:
Example: windows_user_info{username=“dell”,session=“console”,id=“3”,state=“Active”,idle_time=“none”,logon_time=“09-06-2026 10:29 AM”} 1
Step 7: Verify Windows Exporter Metrics
Open:
Search:
windows_user_info
Expected:
windows_user_info{username=“dell”,session=“console”,state=“Active”} 1
Step 8: Configure Task Scheduler
To update the metric automatically every minute:
General Tab
Run whether user is logged on or not
Run with highest privileges
Trigger Tab -
Daily
Repeat task every: 1 minute
Duration: Indefinitely
Action Tab
Program:
powershell.exe
Arguments:
Conditions Tab
Settings Tab
Enable:
• Allow task to be run on demand
• Run task as soon as possible after a scheduled start is missed
Save the task.
Step 9: Verify Prometheus
Open Prometheus:
http://localhost:9090
Execute:
windows_user_info
Expected result:
windows_user_info{username=“dell”} 1
Step 10: Create Grafana Dashboard
Dashboard Output
The dashboard successfully displays:
| User Name | Logon Time | State |
| dell | 09-06-2026 10:29 AM | Active |
Administrators can instantly identify who is logged in and their current session status.
Benefits
- Real-time Windows user monitoring
- No additional agents required
- Uses existing Prometheus infrastructure
- Easily scalable across multiple Windows servers
- Customizable Grafana dashboards
Conclusion
By combining PowerShell, Windows Exporter Textfile Collector, Prometheus, and Grafana, we created a lightweight and efficient solution for monitoring active Windows users. This approach provides real-time visibility into user sessions and can be extended to include additional system audit information as needed.
