grafana-8.0.2-1.x86_64.rpm
CentOS Linux release 7.9.2009 (Core)
My architecture are Grafana Agent (scrape its own metrics) → Nginx (load balancer redirect to Mimir cluster) → Grafana Mimir Cluster (three node running in bare-metal deployment) → Grafana
I’m learning Grafana Mimir and trying to follow the websitemonitor-grafana-mimirpart to create Grafana Mimir dashboard. -
According to grafana website, I collected metrics as [Collecting metrics and logs from Grafana Mimir | Grafana Mimir documentation] said, but the website only gives us the Kubernetes example config. So I created/etc/grafana-agent.yamlby my own as following:
server:
log_level: warn
metrics:
wal_directory: /tmp/wal
global:
remote_write:
- url: http://load-balancer:9009/api/v1/push
headers:
X-Scope-OrgID: mimir-monitor
integrations:
agent:
enabled: true
node_exporter:
enabled: true
include_exporter_metrics: true
disable_collectors:
- "mdadm"
And then, because I’m not using Kubernetes to setup Grafana Mimir, so I followed steps in [About Grafana Mimir dashboards and alerts requirements | Grafana Mimir documentation] to re-compile the dashboard json file.
What happened?
After importing re-compiled dashboard to Grafana, the dashboard didn’t work as expected. When I try to run query to search Grafana Mimir metrics, it seemed that there’s no related metric field as I thought. -
I expected to see some data while importing those re-compiled dashboard. I’m not sure it’s Grafana Agent setting’s issue or re-compiled dashboard’s issue? -
As above. -
I had some error while running Grafana Agent, but I’m sure Grafana Agent is definitely sending metrics to Grafana Mimir because there are tenant directory called ‘mimir-monitor’ in Mimir’s TSDB.
Jan 06 17:34:33 a73 grafana-agent[30208]: ts=2023-01-06T09:34:33.277745901Z caller=dedupe.go:112 agent=prometheus instance=6983b86a53ab512daa671edbef791e3c component=remote level=error remote_name=6983b8-637728 url=http://load-balancer:9009/api/v1/push msg="non-recoverable error" count=29 exemplarCount=0 err="server returned HTTP status 400 Bad Request: user=mimir-monitor: the sample has been rejected because another sample with a more recent timestamp has already been ingested and out-of-order samples are not allowed (err-mimir-sample-out-of-order). The affected sample has timestamp 2023-01-06T09:32:27.05Z and is from series {__name__=\"node_disk_io_now\", agent_hostname=\"a73\", device=\"sda\", instance=\"a73:9090\", job=\"integrations/node_exporter\"}"
Jan 06 17:35:00 a73 grafana-agent[30208]: ts=2023-01-06T09:35:00.879909538Z caller=dedupe.go:112 agent=prometheus instance=6983b86a53ab512daa671edbef791e3c component=remote level=warn remote_name=6983b8-637728 url=http://load-balancer:9009/api/v1/push msg="Failed to send batch, retrying" err="server returned HTTP status 500 Internal Server Error: rpc error: code = DeadlineExceeded desc = context deadline exceeded"
- Did you follow any online instructions? If so, what is the URL?
As above.
