Using k6, can we connect to mongo DB and execute statements to fetch or insert in to collection?
If yes, more info or any link to documentation will help a lot
Thanks
Thanks
We don’t support MongoDB in core k6 yet, sorry. Looking around, it seems like someone from the k6 community has created a MongoDB xk6 extension recently though: GitHub - chinazhenzhen/xk6-mongo: xk6-mongo
If that’s not enough for your needs, you can read more information about xk6 extensions here:
Usually, K6 is used to implement performance tests over API or webs. Those are the ones that connect to the database, so I recommend you implement an API that does that the way that simulates the system under load and then you use it from k6.
That would be the easiest.
