How to connect sql db in k6 for dynamic data
Hi @Quality136
Welcome to the community forum ![]()
You can use the xk6-sql extension. And find some examples in the blog Load Testing SQL Databases with k6.
I hope this helps.
Cheers!
Hi @Quality136
I hope this helps.
Cheers!
