Hi Team,
We are running mongoDB community version and require to query the data in grafana dashboard
Found enterprise datasource for this but require a data source for mongo DB community - please suggest me solutions
Hi Team,
Unfortunately, there’s no straightforward solution to connect to MongoDB Community at the moment. For a more detailed answer, check out an earlier reply:
If this is important to you, you can also consider creating a feature request for it on GitHub Discussions:
