I would like to add mongo db as a datasource our grafana account. This will allow us to visualize the data from mongo. I can’t seem to find a direct solution. Is this supported? I saw something about the simple json datasource but that would require me to export the json from mongo and then insert it as a data source for grafana which is redundant.
There is currently no support for MongoDB as a data source and no plugin is being worked on by the community as far as I know. It would be totally possible but it is not on the Grafana team’s current roadmap.
Hello daniellee, it’s possible to integrate this feature in a next release ?
@aikon you should do a PR with that plugin
Would definitely love to have the mongodb as a datasource in grafana.
Come on Grafana! It’s ridiculous to do not support NoSQL databases nowadays!
Well, they finally did it, but it’s available only as an enterprise plugin with subscription. That hurt.
