Hi Team,
I’m running a test on my local it working properly, but when i tried to run it on my docker (docker run -i loadimpact/k6 run - <test.js) I’m getting an error saying they can’t find the remote module. Currently all the modules available on same folder.
- how to tackle the current situation ?
- If we move the modularize the code with different folders, then how can i tackle it ?
Hi @Gerard !
There is a fourm’s post where I explained how to run the k6’s in docker with mounting scripts
If that doesn’t help could you please provide more details about the error that you have?
Cheers!
Hi @olegbespalov
This is my tree structure
When i run a test (cat loginTest.js | docker run -i grafana/k6 run -) i’ll get a message like below
time=“2022-02-25T07:44:13Z” level=error msg="The moduleSpecifier "…/Pages/homePage.js" couldn’t be found on local disk. Make sure that you’ve specified the right path to the file.
Hi @Gerard!
Both commands:
and
Is just “redirecting” the content of a single file to a k6.
Please try to mount the catalog with the scripts as the docker volume, as I linked in the first answer. That way from the inside container you can get access to all files.
@olegbespalov
thanks for the quick response. I’m not a docker expert. Can you tell me based on the tree structure i shared. How to mount it and run the test
So I guess it can be something like:
docker run --rm -v <path to your src>:/scripts loadimpact/k6:latest run /scripts/Test/loginTest.js
So everything that is located in the src will be located inside the container in the folder /scripts/.
Hi @olegbespalov
how to pass the proxy details while running with docker. Normally we are passing like
$env:HTTPS_PROXY=“http://localhost:4128”; k6 run
Hey @Gerard !
Docker has excellent documentation, so you can easily find the answers to such questions.
Just search for the section about environment variables.
Cheers
