yes that is for a docker image of grafana. the github repo you are pointing to and having errors for is not for grafana
I’m trying to use Docker to install Grafana and yet that is not a suitable topic?
but you are not installing grafana. you are installing another repo that has nothing to do with grafana. unless i am in need of another cup of coffee
The error messages are about the directories that are used by Grafana.
Ok, I’m going to say it more plainly: that repository you keep pointing to is pure crap. It was created by someone either negligent or someone who simply doesn’t understand docker.
First of all, the folder data and data/grafana don’t exist before hand. So obviously you cannot change their permissions. You have to create them manually and change the permission on data/grafana (only this one, because it seems that data/db is used by the other container). And to the grafana folder (again, relative path, in the git repository).
It then works without any issues. Insisting that this is a bug while using some random repository on the internet and asking for the grafana staff to fix this… isn’t cool (I’ve nothing to do with them, just for your own information).
You need to understand the basics of docker. This is all it boils down to.
ok, thanks for your feedback.
Well, that repo does use the grafana’s official image. So much is true. But I agree with you.
the error messages could have said something about tesla, google, my kitchen sink but that has no direct bearing on tesla, google or my kitchen. ![]()
In a non-development environment at least I would use named volumes though instead of bind mounts. Actually I would used named volumes anyway if I can access them directly. They are located under /var/lib/docker/volumes.
So you could have something ilke:
volumes:
- questdb-data:/root/.questdb/db
which corresponds then to /var/lib/docker/volumes/questdb-data on the host itself.
ok thanks, I will review.
Including all of the necessary prerequisites and fundamental administration knowledge is difficult for any tutorial. I see that you have opened an issue with the tutorial author, so they may be able to provide further assistance.
As @yosiasz and @cretin have described, this is a permissions issue. I recommend reviewing their suggestions, as well as the solution Usman linked in the Grafana issue you opened.
I’m not sure what distribution you’re running so please refer to more specific documentation as needed, but beginning with reviewing Linux file permissions and file structure should be helpful for this and future projects:
Another tip to tackle this is on the command prompt type the command id
for e.g. I am using the root user for running docker-compose file so (It should return 0 for root)
[root@docker loki-stack]# id -u
0
Open your docker-compose file and
in the grafana section just add this line after the image is picked by you;
user: "0"
Then run this docker command;
[root@docker loki-stack]# docker-compose up -d --force-recreate
And it should not return any errors. I did this recently with the latest grafana version 9.0.3
