Missing panel reference ID
Hello, I’m developing a custom grafana panel and when I’m using this panel (by installing it locally in my grafana) in dashboard I have error notification Missing panel reference ID. Can someone help me figuring out what’s the case there? I guess it can be related with JSON model Id naming convention, I could find there that the panel id should follow “Grafana naming convention” but I cannot find grafana naming convention anywhere. My panel id is for now testplugin-testplugin-panel.
Can someone help me with this case?
Thanks a lot!
@adamhowaniec Naming convention can be found in the schema file
https://raw.githubusercontent.com/grafana/grafana/master/docs/sources/developers/plugins/plugin.schema.json
"id": {
      "type": "string",
      "description": "Unique name of the plugin. If the plugin is published on grafana.com, then the plugin `id` has to follow the naming conventions.",
      "pattern": "^[0-9a-z]+\\-([0-9a-z]+\\-)?(app|panel|datasource|secretsmanager)$"
I would suggest to double check your plugin.json and compare with the configuration you got from the plugin-tools.
It turned out that I was missing org name in my panel id. Now it works and shows no errors. Thank you very much :slight_smile:
@adamhowaniec If you use VSCode, it validates plugin.json against schema and displays this kind of issues when editing.
