Missing metrics in Prometheus when using xk6-output-prometheus-pushgateway with k6-operator
I’m trying to use the xk6-output-prometheus-pushgateway extension with the k6-operator, but not all metrics are showing up in Prometheus as they do with the remote-write extension, even though I’m using the same test code. For example, I don’t see the checks_rate metric, which is necessary to map errors to specific test cases. Is there any additional setting I should consider here?
Hi @mydotmsg,
The extension in question is not supported by grafana or the k6 team in particular - that is to say it is a community one.
I don’t know if its author is reading this forum on the regular, so it might be better opening an issue in the repo.
Hope this helps you!
Thank you for the tip! I followed her suggestion and created an issue in the repo, but so far, I haven’t received a response.
Maybe the extension isn’t very popular, so I might have to look for an alternative solution.
