Has anyone tested the Prometheus integration with the experimental-prometheus-rw output flag? I spin up a fresh new Prometheus instance on my local with Brew with remote-write-receiver feature flag enabled, which was the only customization I did.
And I was using a really simple http get script to test this integration out. Below is the script:
import http from "k6/http";
export default function () {
http.get("[http://test.k6.io](http://test.k6.io/)");
I had this script running for 30 secs as there was a known issue with very short durations. I’ve run the test couple of times so far, however I didn’t see any k6-related metrics reporting to Prometheus by searching k6 key word on http://localhost:9090/metrics
❯ K6_PROMETHEUS_RW_SERVER_URL=http://127.0.0.1:9090/api/v1/write \
k6 run k6-http_get.js -d 30s -o experimental-prometheus-rw
/ __________ \ |__| \__\ \_____/ .io
execution: local
script: k6-http_get.js
output: Prometheus remote write (http://127.0.0.1:9090/api/v1/write)
scenarios: (100.00%) 1 scenario, 1 max VUs, 1m0s max duration (incl. graceful stop):
* default: 1 looping VUs for 30s (gracefulStop: 30s)
running (0m30.0s), 0/1 VUs, 176 complete and 0 interrupted iterations
default ✓ [======================================] 1 VUs 30s
data_received..................: 2.1 MB 70 kB/s
data_sent......................: 36 kB 1.2 kB/s
http_req_blocked...............: avg=1.19ms min=2µs med=5µs max=165.42ms p(90)=7µs p(95)=7.44µs
http_req_connecting............: avg=615.97µs min=0s med=0s max=73ms p(90)=0s p(95)=0s
http_req_duration..............: avg=84.04ms min=69.78ms med=73.14ms max=449.4ms p(90)=77.41ms p(95)=108.8ms
{ expected_response:true }...: avg=84.04ms min=69.78ms med=73.14ms max=449.4ms p(90)=77.41ms p(95)=108.8ms
http_req_failed................: 0.00% ✓ 0 ✗ 352
http_req_receiving.............: avg=97.74µs min=43µs med=95µs max=1.32ms p(90)=130.9µs p(95)=142.89µs
http_req_sending...............: avg=23.59µs min=10µs med=23µs max=240µs p(90)=32µs p(95)=36µs
http_req_tls_handshaking.......: avg=498.74µs min=0s med=0s max=93.63ms p(90)=0s p(95)=0s
http_req_waiting...............: avg=83.92ms min=69.67ms med=73ms max=449.31ms p(90)=77.31ms p(95)=108.66ms
http_reqs......................: 352 11.720653/s
iteration_duration.............: avg=170.62ms min=142.72ms med=145.77ms max=523.69ms p(90)=229.72ms p(95)=365.56ms
iterations.....................: 176 5.860327/s
vus............................: 1 min=1 max=1
vus_max........................: 1 min=1 max=1
