Missing documentation on how to achieve data links in the Nodes and Expanding Hidden Nodes for NodeGraph plugin
Hi Team,
The current Node Graph panel official doc has a demo showcasing the feature abilities for Traces(Node links) and Exploring hidden nodes. But there is no documentation around it or even examples for the users to understand how this can be achieved for their similar use cases.
I have tried to explore using the TestData DB to render a sample Node graph which has data links in the Node context header but upon inspecting, I couldn’t find any help on how to get there.
Pls can you confirm this is the case that the docs are missing. If so, appreciate if you can share insights on how this can be done and when the official docs will be available on implementing the feature.
Thanks
Vince
