Migration from sqllite to Postgres using windows
Hello There, today i’m work on project that I need use the windows server with grafana, but the for policy I can’t use the sqllite, so I will need migrate to postgres, I was try some times but my service not start.
I used also the “Full convert software”, to convert sqllite on postgres.
There another way to migrate?
is this a fresh grafana install or an existing one? if an existing one how many dashboards does it have?
There is an existent, I have only two dashboard
If nothing else other than those 2 dashboards keep it simple
Export the dashboards’ JSON
Spin the new grafana pointing to postgres
Import the dashboards’ JSON
Or even simpler just recreate the dashboards on new server
Or stop current grafana service, change ini file to point to postgres. Then start service then on same grafana recreate dashboards
My question is, I need just appoint the ini file to Postgres and the database Will be created automatically? Or I need to do something to recreate the grafana structure on db
You first need to manually create the database with proper permission for the grafana user
Then when you restart the grafana service it should recreate all the tables
Thanks!! Its work for me!
